  3. regarding simulating a verilogams file in cadence for implementing...
  • Subscribers 136
  • Views 5709
regarding simulating a verilogams file in cadence for implementing mtj
JJ202409288946
JJ202409288946 over 2 years ago
I have a verilogams code for implementing mtj model, so firstly I have created the verilogams file , then created symbol from the code. Then i have designed a test circuit and put the instance i have created into the circuit. Then i have done transient analysis. But firstly it was giving a an error of   "unable to descend into any of the views defined in the view list, 'spectre cmos_sch cmos.sch schematic veriloga', for the instance 'i7' in cell 'test1'. add one of these views to the cell 'mtj_model' in the library 'mtj_vb', or modify the view list so that it contains an existing view"  then according to your suggestion , i have added verilogams view n setup->environment
then it is giving the error I have shown above. I have also attached the picture of the circuit. Please help me out here
also to mention, in this circuit, the mtj_model and initials both are the symbol created from separate  verilogams files
    Two issues:
    1. VerilogAMS cannot be used in Spectre, only in AMS Designer. That's because VerilogAMS can contain features that require a digital (event-driven) engine and hence need mixed-signal simulation. This is true even if the VerilogAMS view only uses the analog subset of VerilogAMS. If that's the case (which I would guess it would be for a Magnetic Tunnel Junction device) then you should create a veriloga view instead. This will then be supported during netlisting, and in Spectre too.
    2. You appear to have included the gpdk090 models twice, or incorrectly at least. Check your Setup→Model Libraries in ADE to ensure they are not listed twice (also check Setup→Simulation Files in case you have included them there too).
  • JJ202409288946
    JJ202409288946 over 2 years ago in reply to Andrew Beckett
    Thanks Andrew!
    I have solved the problem of running the simulation in spectre with verilogams code, Now the netlist doesnt give any error
    But a new problem is that whenever I try to plot the currents of the terminals the transient analysis is not working, but the plots of voltages are fine, but it could not plot the currents. I am attaching here the plots , netlist file, ams code and the ckt :
    Netlist:
    // Generated for: spectre
    // Generated on: Oct 6 12:28:19 2024
    // Design library name: mtj_vd
    // Design cell name: test
    simulator lang=spectre
    global 0
    include "/home/vlsi11/g11/include_ams.scs"
    include "/home/eda/cadence/tech/process/gpdk090_v4.6/libs.oa22/gpdk090/../../models/spectre/gpdk090.scs" section=NN
    // Library name: mtj_vd
    // Cell name: test
    // View name: schematic
    I0 (pos neut 0 net08 net013 _mz) mtj_model use_as_dmtj=1 \
    plank_constant=1.054e-27 electron_charge=1.602e-19 \
    gyromagnetic_ratio=1.7608e+07 alpha=0.002 Ms=1050 Hk=250 Vh=0.5 \
    Rp=1500 tmr=2 length=6e-06 width=6e-06 thickness=1e-07 tox=1.2e-09 \
    kb=1.38e-16 T=300
    I1 (net011 net012 net010) Initial kb=1.38e-16 T=300 Ms=1050 Hk=250 \
    NM0 (net4 net1 pos pos) gpdk090_nmos1v w=(1.2u) l=100n as=336f ad=336f \
    ps=2.96u pd=2.96u m=(1)*(1) simM=(1)*(1)
    V1 (net1 0) vsource type=pulse val0=5 val1=0 period=10n rise=10p fall=10p \
    width=5n
    C2 (net4 0) capacitor c=250f
    C1 (pos 0) capacitor c=1f
    C0 (net1 0) capacitor c=250f
    R4 (_mz net010) resistor r=100m
    R5 (net013 net012) resistor r=100m
    R6 (net08 net011) resistor r=100m
    R3 (neut 0) resistor r=1M
    V0 (net4 0) vsource dc=5 type=dc
    ic _mz=0.5 net013=0.5 net08=0.5 net011=0.5 net012=0.5 net010=0.5
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
    tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
    checklimitdest=psf
    tran tran stop=100n errpreset=conservative write="spectre.ic" \
    writefinal="spectre.fc" annotate=status maxiters=5
    save I0pos I0mz I0my I0mx
    it seems like the mtj is not giving output correctly but i am pretty sure my code is fine, but the plot is not showing for currents
    Please help me out Sir
