  3. use cadence liberate to characterize a cell that has capacitance...
  • Subscribers 136
  • Views 2391
use cadence liberate to characterize a cell that has capacitance and resistance,but failed...
TH20240830782
TH20240830782 over 2 years ago
I need to characterize a cell that has capacitance and resistance , I specified leafcell, but something went wrong, here is the ERROR:
ERROR (SFE-396): "/home/IC/Project/smic18ee_lab/K_library/lab/MODELS/smic18ee_standalone/e2r018_real5v_v0p2_3t_spe.mdl" 839: Model `rnpo2sabe2r' has already been defined.
ERROR (SFE-396): "/home/IC/Project/smic18ee_lab/K_library/lab/MODELS/smic18ee_standalone/e2r018_real5v_v0p2_3t_spe.mdl" 846: Model `pipe2r' has already been defined.
here is the input file :
# Liberate Characterization Tcl File
# MODS by Tom Briggs (C) 2018
# Set the run directory. Here we use PWD, but in a distributed
# environment, it is recommended to directly specify the full path
# instead of using "PWD"
set rundir $env(PWD)
# Create the directories Liberate will write to.
exec mkdir -p ${rundir}/LDB
exec mkdir -p ${rundir}/LIBRARY
exec mkdir -p ${rundir}/DATASHEET
set_operating_condition -voltage 5 -temp 25
set_var extsim_model_include ${rundir}/MODELS/smic18ee_standalone/include_ff.scs
# d g s b
define_leafcell -type nmos -pin_position { 0 1 2 3 } \
{ nlv50e2r }
define_leafcell -type pmos -pin_position { 0 1 2 3 } \
{ plv50e2r }
define_leafcell -extsim_model -type c -pin_position { 0 1 } \
{ pipe2r }
define_leafcell -extsim_model -type r -pin_position { 0 1 } \
{ rnpo2sabe2r }
source ${rundir}/TEMPLATE/template.tcl
## Load Spice models and subckts ##
#set spicefiles $rundir/MODELS/include_SS.sp
foreach cell $cells {
lappend spicefiles ${rundir}/NETLIST/${cell}.scs
read_spice -format spectre ${spicefiles}
#read_spice -format spectre ${rundir}/NETLIST/INVX1.scs
## Characterize the library for NLDM (default), CCS and ECSM timing.
##char_library -ccs -ecsm -cells {dff_x1}
char_library -cells ${cells}
## Save characterization database for post-processing ##
write_ldb ${rundir}/LDB/ship_cells.ldb
write_library -overwrite ${rundir}/LIBRARY/ship_ccs_adder.lib
write_datasheet -format html -dir ${rundir}/DATASHEET "Ship Libs"
  • Guangjun Cao
    Guangjun Cao over 2 years ago
    ERROR (SFE-396) is from Spectre during simulation/netlist read-in. Can you check model wrapper to see if the sesctions containing flagged models, have been included twice? or the models have been included more than once --- make sure your netlist files do not 'include' model files.
    you use -extsim_model for the two leafcells. Do you also include the model through extsim_deck_header? If so, does your model wrapper also have these model files included?
    Other suggestions,
    1. add '-extsim spectre' to you char_library, when you use extsim_model_include
    2. add 'set_var tmpdir [pwd]/tmpDir'. when you see simulation-related errors, go into one of the subdir inside tmpDir/alt*, check sim.lis and sim.sp. you will also need to use 'set_var ski_enable 0', when doing such debug.
    Guangjun
  • TH20240830782
    TH20240830782 over 2 years ago in reply to Guangjun Cao
    sir,thanks for your reply! According to your suggestions, the ERROR 369 is gone ,but the new ERROR is
    INFO (LIB-511): (define_leafcell): Leafcell 'nlv50e2r' (instance) has been identified with pin_position (0 1 2 3) mapped to (D G S B).
    INFO (LIB-511): (define_leafcell): Leafcell 'plv50e2r' (instance) has been identified with pin_position (0 1 2 3) mapped to (D G S B).
    INFO (LIB-511): (define_leafcell): Leafcell 'pipe2r' (instance) has been identified with pin_position (0 1) mapped to (A C).
    INFO (LIB-511): (define_leafcell): Leafcell 'rnpo2sabe2r' (instance) has been identified with pin_position (0 1) mapped to (A C).
    WARNING (LIB-54): Some output transitions did not cross both 'measure_slew_*' thresholds for arc of cell:'rs_s2_1', r_pin:'R', r_pin dir:'r', pin:'Q', pin dir:'r', type:'combinational rise_transition' when: S. To debug, review the saved simulation results for deck: 'delay_1'. The program will automatically rerun with an extended sim_duration which equals to current estimated sim_duration multiplies 'variation_sim_tran_end_extend_factor' if 'retry_count' is greater than 0. If this message is displayed as Error eventually, which means all the retries are failed, possible solution includes manually setting 'extsim_exclusive' to 1 and 'sim_estimate_duration' to 0 with increased 'sim_duration' as needed and rerun.
    WARNING (LIB-54): Some output transitions did not cross both 'measure_slew_*' thresholds for arc of cell:'rs_s2_1', r_pin:'R', r_pin dir:'r', pin:'Q', pin dir:'r', type:'combinational rise_transition' when: !S. To debug, review the saved simulation results for deck: 'delay_2'. The program will automatically rerun with an extended sim_duration which equals to current estimated sim_duration multiplies 'variation_sim_tran_end_extend_factor' if 'retry_count' is greater than 0. If this message is displayed as Error eventually, which means all the retries are failed, possible solution includes manually setting 'extsim_exclusive' to 1 and 'sim_estimate_duration' to 0 with increased 'sim_duration' as needed and rerun.
    WARNING (LIB-54): Some output transitions did not cross both 'measure_slew_*' thresholds for arc of cell:'rs_s2_1', r_pin:'S', r_pin dir:'f', pin:'Q', pin dir:'r', type:'combinational rise_transition'. To debug, review the saved simulation results for deck: 'delay_4'. The program will automatically rerun with an extended sim_duration which equals to current estimated sim_duration multiplies 'variation_sim_tran_end_extend_factor' if 'retry_count' is greater than 0. If this message is displayed as Error eventually, which means all the retries are failed, possible solution includes manually setting 'extsim_exclusive' to 1 and 'sim_estimate_duration' to 0 with increased 'sim_duration' as needed and rerun.
    WARNING (LIB-54): Some output transitions did not cross both 'measure_slew_*' thresholds for arc of cell:'rs_s2_1', r_pin:'R', r_pin dir:'r', pin:'QN', pin dir:'r', type:'combinational rise_transition' when: S. To debug, review the saved simulation results for deck: 'delay_5'. The program will automatically rerun with an extended sim_duration which equals to current estimated sim_duration multiplies 'variation_sim_tran_end_extend_factor' if 'retry_count' is greater than 0. If this message is displayed as Error eventually, which means all the retries are failed, possible solution includes manually setting 'extsim_exclusive' to 1 and 'sim_estimate_duration' to 0 with increased 'sim_duration' as needed and rerun.
    WARNING (LIB-54): Some output transitions did not cross both 'measure_slew_*' thresholds for arc of cell:'rs_s2_1', r_pin:'R', r_pin dir:'r', pin:'QN', pin dir:'r', type:'combinational rise_transition' when: !S. To debug, review the saved simulation results for deck: 'delay_6'. The program will automatically rerun with an extended sim_duration which equals to current estimated sim_duration multiplies 'variation_sim_tran_end_extend_factor' if 'retry_count' is greater than 0. If this message is displayed as Error eventually, which means all the retries are failed, possible solution includes manually setting 'extsim_exclusive' to 1 and 'sim_estimate_duration' to 0 with increased 'sim_duration' as needed and rerun.
    WARNING (LIB-54): Some output transitions did not cross both 'measure_slew_*' thresholds for arc of cell:'rs_s2_1', r_pin:'S', r_pin dir:'f', pin:'QN', pin dir:'r', type:'combinational rise_transition'. To debug, review the saved simulation results for deck: 'delay_8'. The program will automatically rerun with an extended sim_duration which equals to current estimated sim_duration multiplies 'variation_sim_tran_end_extend_factor' if 'retry_count' is greater than 0. If this message is displayed as Error eventually, which means all the retries are failed, possible solution includes manually setting 'extsim_exclusive' to 1 and 'sim_estimate_duration' to 0 with increased 'sim_duration' as needed and rerun.
    MEM=973 MB
    Characterization finished at Mon Oct 7 16:55:25 2024
    Characterization statistics:
    Number of cells to characterize = 1
    Number of define_cell commands = 1
    Number of passing cells = 0
    Number of failing cells = 1
    WARNING (LIB-422): (char_library): 1 cells failed during characterization. Review the .log file for previous Warnings and Errors that could explain the failures. Update the Tcl script and rerun.
    List of failing cells {
    rs_s2_1
    Performance statistics (4 thread(s)):
    Spectre CPU time: 0.00 hours (10.78 seconds)
    Total PreProcessing time: 0.00 hours (0.10 seconds)
    Total cpu time: 0.00 hours (11.51 seconds)
    Wall clock time: 0.00 hours (6.00 seconds)
    Finished Liberate Execution.
    Updating library database /home/IC/Project/smic18ee_lab/K_library/lab/LDB/ship_cells.ldb.59.gz
    Memory usage: 974 Mbytes
    LIBERATE parameter "mx_format_expand_buses" set to "0"
    LIBERATE parameter "ecsm_multi_stage_cap_mode" set to "0"
    LIBERATE parameter "ccsp_mode" set to "0"
    ERROR (LIB-632): (write_library) : The library will be incomplete because only failing characterization results exist for cell=rs_s2_1, pin=Q, related_pin=R, rise_power. Check and fix the characterization errors, recharacterize the design, and rewrite the library.
    ERROR (LIB-632): (write_library) : The library will be incomplete because only failing characterization results exist for cell=rs_s2_1, pin=Q, related_pin=R, timing_type=combinational, timing_sense=positive_unate, cell_rise. Check and fix the characterization errors, recharacterize the design, and rewrite the library.
    ERROR (LIB-632): (write_library) : The library will be incomplete because only failing characterization results exist for cell=rs_s2_1, pin=Q, related_pin=R, timing_type=combinational, timing_sense=positive_unate, rise_transition. Check and fix the characterization errors, recharacterize the design, and rewrite the library.
    ERROR (LIB-632): (write_library) : The library will be incomplete because only failing characterization results exist for cell=rs_s2_1, pin=Q, related_pin=R, timing_type=combinational, timing_sense=positive_unate, when=!S, cell_rise. Check and fix the characterization errors, recharacterize the design, and rewrite the library.
    ERROR (LIB-632): (write_library) : The library will be incomplete because only failing characterization results exist for cell=rs_s2_1, pin=Q, related_pin=R, timing_type=combinational, timing_sense=positive_unate, when=!S, rise_transition. Check and fix the characterization errors, recharacterize the design, and rewrite the library.
    ERROR (LIB-632): (write_library) : The library will be incomplete because only failing characterization results exist for cell=rs_s2_1, pin=Q, related_pin=R, timing_type=combinational, timing_sense=positive_unate, when=S, cell_rise. Check and fix the characterization errors, recharacterize the design, and rewrite the library.
    ERROR (LIB-632): (write_library) : The library will be incomplete because only failing characterization results exist for cell=rs_s2_1, pin=Q, related_pin=R, timing_type=combinational, timing_sense=positive_unate, when=S, rise_transition. Check and fix the characterization errors, recharacterize the design, and rewrite the library.
    thanks for your patience
    Sincerely, All the best,
