  3. Virtuoso_'Analog_Design_Environment_L', 'Analog_Design_Environment_XL...
  • Subscribers 125
  • Views 588
Virtuoso_'Analog_Design_Environment_L', 'Analog_Design_Environment_XL', and 'Analog_Design_Environment_L' License Checkout Failure IC 6.1.8
SA202410022720
SA202410022720 11 months ago
When I simulate a simple circuit with in IC 6.1.8, and I want to use ADE L, ADE XL and ADE GXL I encounter License Checkout Failure
The exact error message is:
ERROR (ELI-00111) Failed to check out license 'Analog_Design_Environment_L'.
ERROR (ELI-00111) Failed to check out license 'Analog_Design_Environment_XL'.
ERROR (ELI-00111) Failed to check out license 'Analog_Design_Environment_GXL'.
Any ideas?
Thanks.
    Andrew Beckett 11 months ago
    Please contact customer support. Without knowing what licenses you should have available, and probably needing to see your setup, it's going to be quite hard to diagnose.
