  3. Some error while running Quantus(Assura) Parasitc extraction...
  • Subscribers 136
  • Views 1420
Some error while running Quantus(Assura) Parasitc extraction run form
Sameerpy
Sameerpy over 2 years ago
These errors occurred while running Quantus(Assura).
Cadence Quantus Extraction - 64-bit Parasitic Extractor - Version
20.1.1-s233 Wed Mar 25 13:13:47 PDT 2020
Copyright 2020 Cadence Design Systems,
Inc.
INFO (EXTQRCXOPT-243) : For Assura inputs, if the "output_setup -directory_name" option was not
specified, it is automatically set to the input directory.
INFO (LBRCXU-108): Starting
/cadence/ASSURA41/tools.lnx86/assura/bin/rcxToDfII /home/sameer23185/thesis/2020_1/SCH_lay/__qrc.rcx_cmd -t -f /home/sameer23185/thesis/2020_1/SCH_lay/extview.tmp -w /home/sameer23185/thesis/2020_1/SCH_lay
WARNING (LBRCXU-172): m2write fd 10, 1 tries, bytes -1 of 38, errno 9 Bad file descriptor
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.46s.
@(#)$CDS: rcxToDfII_64 version av4.1:Production:dfII6.1.8-64b:IC6.1.8-64b.83 12/20/2018 04:06 (sjfib187) $
sub-version 4.1_USR6, integ signature 2018-12-20-0335
run on edatools-server1.iiitd.edu.in from /cadence/ASSURA41/tools.lnx86/assura/bin/64bit/rcxToDfII on Mon Oct 14 21:05:59 2024
Loading tech rule set file : /cadence/FOUNDRY/analog/180nm/pv/assura/techRuleSets
*WARNING* LIB functional from File /home/sameer23185/thesis/2020_1/cds.lib Line 4 redefines
LIB functional from File /cadence/IC618/tools.lnx86/dfII/etc/cdsDotLibs/artist/cds.lib
Insert UNDEFINE functional
before DEFINE functional
in /home/sameer23185/thesis/2020_1/cds.lib
Or remove or comment out DEFINE functional
in /cadence/IC618/tools.lnx86/dfII/etc/cdsDotLibs/artist/cds.lib
to suppress this warning message.
*WARNING* LIB US_8ths from File /home/sameer23185/thesis/2020_1/cds.lib Line 6 redefines
LIB US_8ths from File /cadence/FOUNDRY/cds.lib
Insert UNDEFINE US_8ths
before DEFINE US_8ths
Or remove or comment out DEFINE US_8ths
in /cadence/FOUNDRY/cds.lib
*WARNING* The directory: '/cadence/ASSURA41/tools.lnx86/dfII/etc/cdslib/artist/functional' does not exist
but was defined in libFile '/home/sameer23185/thesis/2020_1/cds.lib' for Lib 'functional'.
*WARNING* The directory: '/cadence/ASSURA41/tools.lnx86/dfII/etc/cdslib/artist/analogLib' does not exist
but was defined in libFile '/home/sameer23185/thesis/2020_1/cds.lib' for Lib 'analogLib'.
Loading gpdk180/libInit.il ...
Loading gpdk180/loadCxt.ile ... done!
Loading context 'gpdk180' from library 'gpdk180' ... done!
Loading context 'pdkUtils' from library 'gpdk180' ... done!
Loading gpdk180/.cdsenv ... *WARNING* Cannot find /cadence/ASSURA41/tools.lnx86/dfII/etc/tools/spectre directory to load environment variables
done!
Loading gpdk180/libInitCustomExit.il ...
* Cadence Design Systems, Inc. *
* Generic 180nm PDK *
* (gpdk180) *
* Version 3.2 *
done!
Loaded gpdk180/libInit.il successfully!
*WARNING* Cannot find /cadence/ASSURA41/tools.lnx86/dfII/etc/tools/hspiceD directory to load environment variables
Loading gpdk045/libInit.il ...
Loading context 'gpdk045' from library 'gpdk045' ... done!
Loading gpdk045/gpdk045_customFilter.il ... done!
Loading gpdk045/libInitCustomExit.il ...
Loading Environment Settings ...
Loading gpdk045/gpdk045_PDKRegistrations.il ... done!
* Generic 45nm PDK *
* (gpdk045) *
VERSION: 6.0 (09-September-2019)
done!
Loaded gpdk045/libInit.il successfully!
Loading gpdk090/libInit.il ...
Loading context 'gpdk090' from library 'gpdk090' ... done!
Loading gpdk090/gpdk090_customFilter.il ... done!
Loading gpdk090/.simrc ... done!
Loading gpdk090/libInitCustomExit.il ... Loading Environment Settings ...
*WARNING* envSetVal: Can't set the value of variable 'extractVerifySubstrate',
in tool[.partition] 'layout' - it has not been registered.
*WARNING* envSetVal: could not find tool[.partition] 'spectre.envOpts'
Loading gpdk090/gpdk090_PDKRegistrations.il ... done!
* Generic 90nm PDK *
* (gpdk090) *
Version : 4.6
Build date: 10-FEB-2011
done!
Loaded gpdk090/libInit.il successfully!
*WARNING* envSetVal: could not find tool[.partition] 'hspiceD.envOpts'
ERROR: Failed to find a cellview for (presistor)
ERROR: Assura is terminating because some library models do not exist.
Your rules and your dfII model libraries are inconsistent.
Assura requires all library models in the rule file be present
in the database when running rcx with the "extracted_view"
option.
INFO (LBRCXU-111): Warning /cadence/ASSURA41/tools.lnx86/assura/bin/rcxToDfII exit with bad status
INFO (LBRCXU-112): Warning Status 256
INFO (LBRCXU-113): Warning Quantus execution terminated
***** aveng fork terminated abnormally *****
