  3. Maestro - Intersymbol Interference (ISI) Jitter measure...
  • Subscribers 136
  • Views 1450
Maestro - Intersymbol Interference (ISI) Jitter measurement
firebolt3
firebolt3 over 2 years ago
I am trying to measure ISI jitter using delay function between PRBS pattern output (includes DCD+ISI jitter) & Clk pattern output (includes DCD jitter only). I need delay seperately for rise & fall edges. For Rise2Rise delay, function should capture only delay between rising edges of both signals at the same time, not at different times. Same is applicable to fall delay also. This delay, either Rise2Rise or Fall2Fall, will eliminate common DCD jitter and left with ISI jitter only. But my delay expression is not working properly. Below image (shared in link) clearly shows what I am trying to measure. Please help.
ISI Jitter Measurement Plots
* Unable to attach image due to unknown error. So, I am sharing image link. Error - An error occurred. Please try again or contact your administrator.
  • firebolt3
    Any help here? I know you guys are busy in your own work. But this is a showstopper for me.
    Andrew Beckett over 2 years ago in reply to firebolt3
    If this is urgent, you should contact customer support, as these forums are done in our own time (including those of us like me who are Cadence employees). The forums are not a substitute for customer support.
    I can't see your picture as it's on a google drive which doesn't work for me (might be because it's blocked for us).
