  3. Bind Key for Changing Multiple Layout Grid Controls
  • Subscribers 136
  • Views 6672
sgcad
sgcad over 2 years ago
Hi
To simplify the placement of digital standard cells, I'd like to define a bind key that sets the following grid controls:
  • Type = Lines
  • Minor Spacing = 1.4 um
  • Major Spacing = 5.6 um
  • X Snap Spacing = 0.7 um
  • Y Snap Spacing = 0.7 um
Based on the documentation and various forum threads I came up with the following SKILL code that's placed in the .cdsinit:
procedure(ChangeLayoutSnaps()
    hiGetCurrentWindow()->xSnapSpacing=700
    hiGetCurrentWindow()->ySnapSpacing=700
    hiGetCurrentWindow()->GridSpacing=1.4
    hiGetCurrentWindow()->GridMultiple=4
    hiGetCurrentWindow()->drawDottedGridOn=0
) ;proc
hiSetBindKey("Layout" "<Key>2" "ChangeLayoutSnaps")
This code properly sets the X and Y snap spacing, but does not affect the other three setting (grid type and minor/major spacing).
Could you point me to the issue in my code? Thanks very much for your help.
PS: This technology seems to have nm, not um, as default units, that's why the snap spacing is entered in nm. I've tried to also use nm for the minor/grid spacing, with no change in behavior.
    Some points:
    1. It should be gridSpacing not GridSpacing
    2. It should be gridMultiple not GridMultiple
    3. You should set drawDottedGridOn to nil rather than 0
    4. I don't understand how you would set the xSnapSpacing and ySnapSpacing to 700. The database unit might be nanometers (that's common), but the userUnits are likely to be micron and I don't think it's possible to set it to nanometer (it's not a documented allowed value, and I tried and it didn't accept it). Also, if it did, the UI would be consistent with the bindkey - there's no scaling done by the callback of the display options form. So I think you need to set xSnapSpacing and ySnapSpacing to 0.7 (otherwise it will be 700um). What does geGetEditCellView()~>userUnits and geGetEditCellView()~>DBUPerUU return?
  • sgcad
    sgcad over 2 years ago in reply to Andrew Beckett
    Thanks very much and apologies for the silly oversights. Not yet used to SKILL programming...
    xSnapSpacing, ySnapSpacing, and gridSpacing seem to accept nm just fine. Let me try next week what happens if I go back to um. From the CIW I get:
    1000.0
    "micron"
    Andrew Beckett over 2 years ago in reply to sgcad
    It seems that if you specify xSnapSpacing and ySnapSpacing as an integer, then it's in database units (so if DBUPerUU is 1000, then it will be 0.7um; if DBUPerUU is 2000, it's 0.35um). If you set and then retrieve the xSnapSpacing/ySnapSpacing as an integer - it will return as a float in user units.
    If you set it as a float, it's in user units. So setting to 0.7 should be fine too.
  • sgcad
    Thanks, I can confirm this behavior from my side.
