  3. Recommended delimiter in DSPF for deep probing
  • Subscribers 136
  • Views 5741
unSkilled
unSkilled over 2 years ago
Virtuoso IC Studio IC23.1-64b.ISR8.40
I'm having issues probing signals from an extracted view and the guides in the support.cadence.com are wrong as well.From the results browser I probe the voltage of interest and get this expression:
v("u_lfxo.u_gp_lfxo_top\\/u_agc\\/in_cmp_p" ?result "tran")
So one would think that using u_lfxo.u_gp_lfxo_top\\/u_agc\\/in_cmp_p as signal path in the deep probe does the job. However, nothing gets probed.
I found this in the forum:
deepprobe not working for extracted cellview in ADE-XL run.
But the suggested underscore would also be a problem because we use underscores in the instance names. What other character could be used as delimiter that does not require escaping in the deep probe syntax? Honestly this is a task that should be very straightforward to but the tool behavior is buggy.
  • unSkilled
    It seems that using $ as dspf divider works without having to escape it.
  • unSkilled
    There seems to be a hiccup in the tool though. Trying to fix this issue I used the hier_delimiter="/" option in the miscellaneous tab of the simulator->options->analog.
    Now, even when I delete, reset to defaults or explicitly defined to "." the delimiter doesn't return to "." I have even close the session and changed machines (I'm running in a server farm).
    Is there a way to set the hier_delimiter as an environment variable?
