  3. Clicking Check and Save in Verilog Editor of Virtuoso returns...
  • Subscribers 129
  • Views 1621
Clicking Check and Save in Verilog Editor of Virtuoso returns error 'Extract Failed for Cellview"
DK202409295316
DK202409295316 over 1 year ago
I created a new Verilog cellview in the library I usually use in Virtuoso, and wrote the following code:
module digitalinverter (Vin,Vout);
    input wire Vin;
    output wire Vout;
    assign Vout=~Vin;
endmodule
However, when I go to click the "Build a database of instances, nets, and pins found in file," I get the following popup, as well as the pasted CIW output.
CIW Output:
(TE-4223): Extracting cellview 'FA24SP25Analog digitalinverter functional' ...
Loading hdlPkg.cxt
ERROR (TIVLOG-43): The module 'digitalinverter' is not found in the source file inside the cellview 'FA24SP25Analog digitalinverter functional'.
Correct the module name in the source file or rename the cell to resolve the error.
ERROR (TIVLOG-34): Unable to parse the file, '/home/dgk64/SKY130_PDK/FA24SP25Analog/digitalinverter/functional/verilog.v', for cellview '(FA24SP25Analog digitalinverter functional)'.
ERROR (TI-7001): Cannot load the connectivity information for cellview 'FA24SP25Analog/digitalinverter/functional' in text file
'/home/dgk64/SKY130_PDK/FA24SP25Analog/digitalinverter/functional/verilog.v'.
Verilog *E,PARSEERR: Either there are parsing errors or cell digitalinverter
                    is not found in /home/dgk64/SKY130_PDK/FA24SP25Analog/digitalinverter/functional/verilog.v
                    file.
*WARNING* (TE-4309): Extract failed for cellview 'FA24SP25Analog digitalinverter functional'
The below is also what I have in my source file that I run before launching Virtuoso, in case that is relevant here:
#Cadence Virtuoso
module load cadence/cadence
module load cadence/innovus
#For parasitic extraction:
export ASSURAHOME=/opt/cadence/assura
export PATH=$ASSURAHOME/tools/bin:$PATH
export QRC_HOME=/opt/cadence/EXT152
export PATH=$QRC_HOME/bin:$QRC_HOME/tools/bin:$PATH
export PATH=/opt/cadence/SPECTRE231/bin:$PATH
unset OA_HOME
export CDS_Netlisting_Mode=Analog
# SKY130 Specific Pegasus
export OA_HOME=~/SKY130_PDK/oa
export PEGASUS_DRC=~/SKY130_PDK/sky130_release/Sky130_DRC
export PEGASUS_LVS=~/SKY130_PDK/sky130_release/Sky130_LVS
Thank you in advance!
