  3. Break a single monte carlo run into two independent run...
  • Subscribers 136
  • Views 3813
Break a single monte carlo run into two independent runs
Shlok Vaibhav
Shlok Vaibhav over 1 year ago
I am running a 300 point monte carlo run where each corner takes quite long to simulate, I would like to break the single run into two separate runs of 150 jobs each, run them on separate machines and later combine the excel files for statistical processing.
However how do i ensure that the 300 corners generated in the two separate runs are the same as those in a single run? Because if i use the same initial seed, i am going to get identical runs, if i use different seeds, i am still not sure how different the distribution is going to be.
What's the way to accomplish this?
