  3. Use a schematic view for an instance inside external HD...
  • Subscribers 136
  • Views 4195
Use a schematic view for an instance inside external HDL
MikeVP
MikeVP over 1 year ago
I'm using xrun 23.03-s009, virtuoso 23.1, ISR10.29.
For a top level simulation, our digital place and route is called out as external HDL in the hierarchy editor.  In the systemVerilog, it calls out an instance of an OTP cell.  Is it possible to have that OTP cell netlist using the schematic view?  The design will netlist, but fails because the OTP instance "is a leaf instance and is unresolved in cellview."
I've tried putting the library in the HED Library List, adding a netlist to the model path, and put an unconnected an instance of the OTP at the top level test bench so it would be netlisted.  Nothing has worked so far.  Any ideas?
