  3. Assembler Re-Evaluate for Canceled simulations not work...
  • Subscribers 136
  • Views 4431
Assembler Re-Evaluate for Canceled simulations not working
StephanWeber
StephanWeber over 1 year ago
I have a big corner run with simulations taking days. For some sims I could see in Results Browser that the event I want to verify is already fine. So I stopped these runs with "Cancel selected run".
Now all sims are done, but most canceled.
E.g. I have outputs with cross statements, and all should be valid. To get the results I could normally simply press the re-evaluate button. But this time I got nothing, instead I still see "canceled" for each output.
I used all and full as mode, but it does not work as usual, although the psf results are clearly present.
What can I do to get the result values as usual? I use icadvm 20.1.500.25.
In CIW I see this:
*Error* _schIsUserEditable: argument #1 should be a string (type template = "t") at line 50 of file "*ciwInPort*" - nil
BTW: My 1st workaround idea was to use the Calculator and the EB (because of dependent expr). However, also this works not fully reliable, and it cannot simply load the csv from output setup table (although both is csv).
It seemed the 1st calculations where fine, but subsequent results where identical, although some parameters where different.
Bye Stephan
  • StephanWeber
    Enrico helped me to find the solution. I needed to select Partial to let ADE also execute the calculations on canceled runs!
    The results then are marked with ? , which is nice.
    Bye Stephan
