  3. calcval doesn't work cross sweep of same test
  • Subscribers 136
  • Views 1282
analog2
analog2 over 1 year ago
hi,
i'm trying to use "calcval" function for the same test with local sweep of "vcc" variable. i want to use an output from one of the sweep points, so i ran the following expression:
calcVal("output_initial_code" "supply_noise_sensitivity_vern132" ?matchParams list(list("vcc" 0.825)))
 from some reason i'm getting "eval error" message said that "?matchParams" can't be use for the same test.
is it true? i realized that "calcval" can be used also for cross sweep of the same test..
  • analog2
    hi,
