  3. VIVA keeps splitting same time axis waveforms into separate...
  • Subscribers 136
  • Views 4530
VIVA keeps splitting same time axis waveforms into separate subwindows
AM202408156233
AM202408156233 over 1 year ago
When plotting expressions from ADE explorer, VIVA seems to inconsistently split waveforms into their own subwindows.
All the expressions in question are of the form:
awvCreateBus("err_mask" list(awvAnalog2Digital(VT("/err_mask<31>") nil nil (VAR("VDD") / 2) nil "center") ... awvAnalog2Digital(VT("/err_mask<0>") nil nil (VAR("VDD") / 2) nil "center")) "Hex")
All the expressions have the same X-axis time base, so this split seems to be a bug in viva.
Has anyone else experienced this and maybe figured out a workaround?
    Not sure I would expect that (I can test this tomorrow, hopefully). Which IC subversion are you using (i.e. what does the Help->About window say - the full version number)?
  • AM202408156233
    AM202408156233 over 1 year ago in reply to Andrew Beckett
    ICADVM20.1-64b.500.24
    Andrew Beckett over 1 year ago in reply to AM202408156233
    I tried this in the same version, and it works OK for me:
    I suggest you contact customer support (submit a support case after logging in).
