  3. Selecting all same cells in layout
  • Subscribers 136
  • Views 4291
TobyK
TobyK over 1 year ago
is there an easy way to select all same cells in a layout?
Best Regards
  • RobMan
    RobMan over 1 year ago in reply to Andrew Beckett +1
    My guess is you want to select all instances of a specific cell name. You can... Tools -> Find... <select options accordingly> Use the Navigator Assistant: Select Instance (objects), add 'Cell Name;…
    What do you mean by this? The question is rather vague - so I'm not really sure what you're asking. Please elaborate.
  • RobMan
      Use the Navigator Assistant: Select Instance (objects), add 'Cell Name; to the visible columns, sort this column then select (this might be impractical if there are a large number of instances).
  • TobyK
    TobyK over 1 year ago in reply to RobMan
    Thank you. That's what I was looking for.
