  3. How to use the array index to parametrize the delay
  • Subscribers 136
  • Views 3636
Svilen64
Svilen64 over 1 year ago
I am trying to figure out how to do the following. I have an array of current sources <9:0> each of the elements of the array has a delay, which is 0*1n for the 0th element, then 1*1n for element 1, 2*1n for element 2 and so forth until element 9 which has a delay 9*1n. How can I do this parametrically so that I won't have to place manually 10 current sources. I don't want to write SKILL for that.
    You can't. You'd need to either manually place 10 current sources or create a PCell to automate this.
