  3. Unable to run PVS Quantus extraction in cds_ff_mpt (finfet...
  • Subscribers 136
  • Views 5700
Unable to run PVS Quantus extraction in cds_ff_mpt (finfet 18nm)
nikhil2798gp
nikhil2798gp over 1 year ago
Hello
I am trying to run PVS Quantus extraction on a layout that is LVS clean I have attached the images showing setup and the errors I am getting. Kindly help me how to resolve this issue.
When I checked the log file for errors it shows below error
*Error* _iliGetSlotSpecs: not a class object or class name – vfoAdvGuardRing
Please find the error log & snippets in the drive link :
drive.google.com/drive/folders/1chjXKqf4jGhmzJkLynGA8Ig2qw1CHQIB?usp=sharing
Thank you.
Nikhil
  • Ganesh
    Ganesh over 1 year ago in reply to Andrew Beckett +1
    Hi Andrew ----------------------------------------------------------------- Name : quantus - Quantus - (64-bit) Description : Quantus Extraction program Version : 20.1.0-p052 Build Ref. No. : 052 IR…
    Can you attach the errors and logs and images here rather than on a google drive? I cannot access that...
  • Ganesh
    Hi Andrew
    I am also seeing the similar issue and the exact error.
    But I am unable to upload error logs or images.
    So I am copy pasting 2 snippets from error logs. Kindly bear with me.
    nikhil2798gp you can confirm if you are seeing the same error. SO that I am not hijacking this thread. If you are seeing different error I will start a new thread
    1)
    INFO (ICEMAP-221908): Reading transfer property file: /opt/PDKs/cds_ff_mpt_v_1.0/qrc/worst/extview.trp
    INFO (LBRCXU-108): Starting
    /opt/cadence/installs/ICADVM181/bin/qrcToDfII -extract both -run_name SPHDRP_Bitcell -call_proc /opt/PDKs/cds_ff_mpt_v_1.0/qrc/worst/callProc.il -cdlout_run_dir /home/semickt/cadWorkDir/cdsffmpt18/Run_Directory_LVS_QRC -check_cell_view TRUE -device_finger_delimiter @ -extracted_view av_extracted -lvs_source agds -cap_models yes -capacitor pcapacitor -res_models yes -resistor presistor -cap_prop_name c -res_prop_name r -replace_square_busbit_delimiter TRUE -t -extview_tmp /tmp/qrc_38421/SPHDRP_Bitcell/extview.tmp -run_dir /tmp/qrc_38421/SPHDRP_Bitcell -lib_name BITCELL_LIBRARY -cell_name SPHDRP_Bitcell -view_name layout_lvs -extview_rul /tmp/qrc_38421/SPHDRP_Bitcell/extview.rul -server /opt/cadence/installs/QUANTUS201/tools.lnx86/extraction/bin/64bit//../shapeServer
    WARNING (LBRCXU-172): m2write fd 10, 1 tries, bytes -1 of 24, errno 9 Bad file descriptor
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.03s.
    device n1svt M n1svt_dev n1svt symbol cds_ff_mpt D G S B
    Loading cds_ff_mpt/libInit.il ...
    Loading cds_ff_mpt/loadCxt.ile ... done!
    Loading context 'cds_ff_mpt' from library 'cds_ff_mpt' ... done!
    Loading context 'pdkUtils' from library 'cds_ff_mpt' ... done!
    Loading cds_ff_mpt/cds_ff_mpt_customFilter.il ... done!
    Loading cds_ff_mpt/libInitCustomExit.il ...
    Loading Environment Settings ...
    Loading cds_ff_mpt/libInitCktPro.il ... done!
    * Cadence Design Systems, Inc. *
    * Generic Finfet Multi Pattern PDK *
    * (cds_ff_mpt) *
    Version File is not available
    done!
    Loading cds_ff_mpt/cds_ff_mptFgrUtil.il ...
    *Error* _iliGetSlotSpecs: not a class object or class name - vfoAdvGuardRing
    failed!
    Loading cds_ff_mpt/cds_ff_mptFgrRing.il ...
    done!
    Failed to load cds_ff_mpt/libInit.il successfully!*WARNING* (defmethod): unknown class cds_ff_mptFgrGuardRing_ver_1 when defining vfoSfDraw method
    2)
    * (cds_ff_mpt) *
    done!
    failed!
    done!
    epick -e V0_0Act_small V0_0Act_new V0_0Act_new2
    geom V0_0Act V0_0Act_new2 - V0_0Act_m1_0conn_0mask1_LiAct,11,i,1
    connect V0_0Act:V0_0Act_new - -
    INFO (LBRCXU-111): Warning /opt/cadence/installs/ICADVM181/bin/qrcToDfII exit with bad status
    INFO (LBRCXU-112): Warning Status 139
    INFO (LBRCXU-113): Warning Quantus execution terminated
    ***** aveng fork terminated abnormally *****
    Andrew Beckett over 1 year ago in reply to Ganesh
    Knowing the Quantus and IC sub-version (and PVS too) might help here? (at the command line, type "quantus -version" "pls -version"' and "virtuoso -W")
  • Ganesh
    Hi Andrew
    IR Build No. : 052
    Build Date : Fri Nov 29 10:55:59 PST 2019
    sub-version ICADVM18.1-64b.500.13
    PVS version PVS 20.11-s024-64b
    Ganesh,
    I would suggest you start by trying to run something newer - Quantus is 5 years old, and the other tools are similarly old. Ideally use the latest versions of Quantus, IC (Virtuoso) and PVS. If it still fails, then contact customer support.
  • Ganesh
    Thanks Andrew
    As you mentioned upgrading to the latest version has solved this issue!!
