  3. ADE output for conditional string from input logic comb...
  • Subscribers 137
  • Views 3402
ADE output for conditional string from input logic combination
StephanWeber
StephanWeber over 1 year ago
I would like to make to ADE setup and testbench more descriptive. E.g. I sweep the variables EN and Idle 0 to 1 in a corner, so 4 combinations:
      corner_Modes
EN    0 1
Idle   0 1
Note: This might be also don in a sweep, instead of within corner setup.
I would then like to have a string as ADE output too, like 00 gives "off", 11="on", 10="idle" and 01="prep-idle".
Is this possible directly as ADE output?
A workaround would be to introduce a string variable and to split the corner into 4 and define the string variable in the corner as separate row.
But this would not work for sweeps, only for parametric sets, and with higher add. effort.
I am no skill expert, but I think for an expert it should be easy and it makes the results table easier to interpret. E.g if Idd output is >1mA and string variable = "off", than I can immediately see something if wrong..
So what I need is creating a function output  from an input logic combination.
It would be also super-flexible for other things, like if specifications also depend on logic mode.
Bye Stephan
