  3. Synchronicity vs maestro view
  • Subscribers 136
  • Views 4050
StephanWeber
StephanWeber over 1 year ago
we use Synchronicity as version control SW. It works fine for schematics, symbols, etc. but not for maestro
E.g. you do a check-out, but still you see a green mark in Library Manager.
And if you then open it, again you will be asked if you want to check out (although you made this 10s ago).
Is there a solution to this issue?
Bye Stephan
    This is rather surprising since Dassault's DesignSync software is widely used and should support Maestro views. I suspect this must be a specific problem in your environment or with the version used. You should contact their customer support (this is not a Cadence tool).
