  3. analogLib/bsource component with complex coefficient
  • Subscribers 136
  • Views 1719
TommasoF
TommasoF over 1 year ago
Hello Everyone,
do you think there is a way to have a complex coefficient in the bsource component like it is shown below ? I have tried "i" and "j" , but complex numbers cannot be netlisted (I read in the forum if I am not wrong), so I am looking for any suggestion, if possible at all.
thanks
Tommaso
    There is some limited support for complex resistance modelling (for example) but this is not documented (currently) - and the syntax is not as you have tried. Please contact customer support to see whether this might be appropriate in your case.
  • TommasoF
    TommasoF over 1 year ago in reply to Andrew Beckett
    thank you Andrew for the prompt reply
  • TommasoF
    TommasoF over 1 year ago in reply to TommasoF
    I just create the case
