  3. Is it possible to access design variable as parameter of...
  • Subscribers 136
  • Views 3441
Is it possible to access design variable as parameter of systemverilog bloc
Mathieu Chene
Mathieu Chene over 1 year ago
Hi everyone,
I'm doing an AMS simulation in which I want to parameterise a output generated by a systemVerilog instance . This should be used in an existing AMS simulation to enter this parameter as an input bus to the DUT.
module test_parametrized_input (Out );
output logic[63:0] Out;
parameter xValue=2;
assign Out=xValue;
endmodule
Here is the maestro view with xValue declared as a design variable:
I tryed to do as in this post in which variable is declared as a parameter with the same name than the design variable.
However it does not seem to work in ams simulation system-verilog.
Hence I wonder if it is even possible ? or must I do it in verilog-a ?
Thanks in advance for your future answer.
Best regards
