  3. Merge buses when creating a symbol from SpectreText net...
  • Subscribers 136
  • Views 3532
Merge buses when creating a symbol from SpectreText netlist
ArthurP
ArthurP over 1 year ago
I have a netlist (constructed with an external tool) under the spectreText format. Pins are declared at different DC level in this same netlist.
I export the netlist and create a new symbol using  the button "Build a database of instances, nets and pins found in file" from the Spectre-Editor. The newly created symbol works and outputs the correct voltages but the buses are not merged. This can gives huge symbols. Is there any way to merge all the pins of the same name (A<0>, A<1>, ..., A<7>) to a single bus of the name A<7:0> ?
Thank you,
Arthur
