  3. Skill function to set x- or y-axis to linear scale
  • Subscribers 136
  • Views 801
TB202408221839
TB202408221839 over 1 year ago
I found following examples to set the axes to logarithmic via a skill command:
Programmatically set y-axis in VIVA in Log Scale - Custom IC Design - Cadence Technology Forums - Cadence Community
With slight modification for family plots, this works nicely.
However setting them back to linear failed. I tried several options like:
- let(((in getData("in" ?result "noise"))) drGetWaveformXVec(in)~>scale="lin" in)
- let(((in getData("in" ?result "noise"))) drGetWaveformXVec(in)~>scale="linear" in)
- let(((in getData("in" ?result "noise"))) drGetWaveformXVec(in)~>scale=nil in)
but none of them worked. What would be the right argument to achieve this?
As a background, for large testbenches with hundreds of expression, I usually write the outputs in a text editor and import them as CSV to maestro. Since the right choice of logarithmic or linear axes depends on the output dynamic range, it needs to be defined individually for each expression. This could be done very fast with a skill command/function as the one above directly when setting up the testbench.
Kind regards,
Thomas
