  3. Back and forward history buttons in Schematic Editor clearing...
  • Subscribers 136
  • Views 3939
Back and forward history buttons in Schematic Editor clearing probed nets?
ES20241003727
ES20241003727 over 1 year ago
Does anyone know of a workaround for the back and forward history buttons in the "Go" toolbar (Window > Toolbars > Go) clearing all probed nets?
I would like to be able to use these buttons to navigate backwards and forwards in the view history while maintaining the nets I have probed, but whenever I use them, all the probes I have on nets get cleared/deleted, even if returning to the cell/view where they were probed. That makes the forward/back functionality almost useless for me.
My project/environment is set up to use IC6.1.8 but I've also tried in IC23.1 and the behavior is the same.
Any ideas?
    Andrew Beckett over 1 year ago in reply to ES20241003727 +1
    No, currently this is not possible. There's an old request (CCR 753983) asking for this, but it's non-trivial. The back and forward buttons are different from using descend and return (the up arrow or…
  • ES20241003727
    I should probably clarify that I am talking about Virtuoso Schematic Editor L.
    No, currently this is not possible. There's an old request (CCR 753983) asking for this, but it's non-trivial. The back and forward buttons are different from using descend and return (the up arrow or up to top arrow) because they re-open the design again rather than restoring the previous hierarchy point. That's a bit of an architectural change and R&D (at the time) said this was a non-trivial change.
    You might want to contact customer support (use the Case menu to submit a support case after logging in) to request a duplicate be filed on your behalf.
