  3. PAM4 eye diagrams in Cadence
  • Subscribers 136
  • Views 5270
TUKA
TUKA over 1 year ago
Dear all,
I have designed a Transimpedance amplifier (TIA) and would like to check the data rate (say 25 GBps or 50 GBps) using eye diagram simulations.
With a transient analysis, I have observed the output voltage signal and did the following in the waveform window:
 Measurements -> Eye Diagram
I have set the start and stop time respectively  as 0 and length of transient simulation. For the unit interval, I gave half of RMS frequency of this output voltage signal.
I am only able to plot the eye diagram for NRZ (2 levels) only.
Could you please let me know how to plot the eye diagram for PAM-4 modulation scheme? Further what are the settings required?
Also, after plotting the eye diagram, how to measure the data rate?
Tuka
  • Ashish Patni
    Ashish Patni over 1 year ago
    Hi Tuka,
    Please refer to the following RAK and see if this helps:
    Article (20511328) Title: ViVA Eye Diagram: NRZ, PAM3 and PAM4
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009mCuWEAU
    With Regards,
    Ashish
  • TUKA
    TUKA over 1 year ago in reply to Ashish Patni
    Dear Ashish Patni,
    Thanks for the link to the article.
    Tuka
