  3. Metric Prefix
  • Subscribers 136
  • Views 3641
Metric Prefix
samirc
samirc over 1 year ago
Hello - Is there a way in ADE/Spectre to plot the frequency response x-axis with kHz, MHz, etc vs the default engineering notation (10^3, 10^4, etc)
    You can't change the numbers on the ticks - if you edit the properties of the axis, you can change between suffix and engineering notation, but this is just for the multiplier shown next to the axis.
    If you want this, please contact customer support (submit a support case after logging in) to request an enhancement.
