  3. SPICEIN for importing netlisting with pPar expressions
  • Subscribers 136
  • Views 4187
PSKR
PSKR over 1 year ago
I want to generate a schematic using SPICE IN. The CDL netlist of the component would look like this. Need the schematic to be generated with these following expression in the property form(CDF). When i import this netlist , i get these errors
.subckt LDMOS_101 BTWO D S G SUB
*.PININFO BTWO:B D:B S:B G:I SUB:I
 XQ0 ISO1 SUB SUB S PNP4 model=pPar("pnpModel") area=pPar("pL")*pPar("tank_area")) mi=pPar("miX")
 XQ1 S ISO1 ISO1 D NPN4 bypass=SVER, Assura, auLvs, auCdl, calibre mi=pPar("miX") area=pPar("adasNum") model=NPN_LDMOS_101
.ends LDMOS_101
ERROR (SPICEIN-102): Spice In failed to parse the cdl netlist file cdl'. You may read log file 'lvsrpt.wrn'
 ERROR (AVLVSNN-10134) : CDL parser encountered error in file 'cdl' on line 76: Error: Unknown Function type.
XQ0 is line 76
The purpose is to create a schematic for multiple components(from one component) which have similar sub-ckt and batch process and import them. Is it possible through spicein.
    Putting pPar() expressions in the netlist doesn't make sense - that's not legal SPICE (or CDL, or Spectre) syntax. Not sure why would expect that to work. Also, that bypass=SVER, Assura... won't work either (as that doesn't look legal).
    You can have parameters in the netlist - e.g. area=pL*tank_area m=miX - but you should also define the parameters (via .PARAM) within the subckt. However, if you do this, the SPICE import converts them to NLP parameter rather than CDF (pPar) parameters. I have some SKILL code to deal with that (not sure I want to post it here because I don't know how robust it is to deal with general cases - it's been used by a few customers here and there to solve specific problems, but I don't think I've done enough widespread testing to be sure it covers everything). It would be better to contact customer support (submit a case after logging in) and then mention this post and the AE can contact me for more details.
