  3. Passing Global Variable to Matlab function
  • Subscribers 136
  • Views 3154
eyalg
eyalg over 1 year ago
I have Matlab function (find_dc) as expression in ADE assembler.
I would like to pass the value of global variable (start_eval) to the function.
I have tried the syntax : find_dc('txoutp', VAR("start_eval"))
but it didn't work.
The only way I managed to get the global variable is by:
rdb.where(Output() == 'start_eval');
start_time = rdb.query().Result(1)
But then I can't know the index I should use if the variable is not constant vs corners or sweep.
Is there an easy way to get the variable value?
