  3. How to Change Default "Model Library Setup" in ADE Assembler...
  • Subscribers 136
  • Views 1891
How to Change Default "Model Library Setup" in ADE Assembler for All Users
baltaci
baltaci over 1 year ago
I use IC23.1.
I would like to modify the default settings of the "Model Library Setup" in ADE Assembler so that a specific model file always uses a particular section. My goal is to make this change persist across Virtuoso relaunches and apply to all users in the company. Currently, when setting up simulations, I have to manually adjust the model section each time. Instead, I would like to define this as the default behavior for all users.
Where should I modify these settings so that they are applied globally?
Many thanks in advance.
    See FAQ: How to set up model files for Spectre in .cdsenv or .cdsinit in ADE?
