  3. "DRC..." and "LVS..." fields are not available in the "Verify...
  • Subscribers 136
  • Views 1794
"DRC..." and "LVS..." fields are not available in the "Verify" tab on IC 23.1
MA202408239313
MA202408239313 over 1 year ago
Recently, due to an OS change, my institutions was forced to migrate from IC 6.1.8 to IC 23.1.
I am using an old PDK (ami06), which only has Diva rule files. I have already tried to run my DRCs on Assura, but since they are not always compatible, I am being blocked by errors.
Going back to the issue itself, right now, we are using IC23.1.43 and assura_64 version av4.1:Production:dfII23.1-64b:IC23.1-64b.ISR9.24.
Even though the Assura tab is available, the "DRC..." and "LVS..." options are not available in the "Verify" tab of the Layout Suite. Rocky Linux 9 is our current OS.
From what could get from the documentation, Diva should be available. However, if you could tell me whether, it is not available anymore in the most recent versions, or if there is another method to open these menus that used to be available in the Verify tab, or if it could be happening due to a problem in my environment setup, I will be grateful.
If you need further information, please let me know.
    See this article which explains how to enable the Diva menus in this release: support.cadence.com/.../ArticleAttachmentPortal
