  3. How can customize the expression rows in maestro to color...
  • Subscribers 136
  • Views 3889
How can customize the expression rows in maestro to color code them?
Purbayan
Purbayan over 1 year ago
High i want to color code each row for better visibility and organization for example i want to colour code rows based on their groups.
For example, CMRR rows as red and GBWP as  blue and so on
I am also open to skill programming so if need in suggestion please feel free to include a example code also with how to implement it in maestro.
    This is not possible.
    You can (in recent IC23.1 ISRs) enable a Tags column (right mouse button over the column headings), and then add tags to classify certain outputs (right mouse button menu over the tags column for a given row), and then you could sort or filter on the tags.
  • Purbayan
    Purbayan over 1 year ago in reply to Andrew Beckett
    Thank you Andrew, This will also work for me
