  3. how to get rid of eval error
  • Subscribers 136
  • Views 3738
Purbayan
Purbayan over 1 year ago
in maestro I am using this equation to get the data at 25C only if((VAR("TEMP") == 25) then IQ else nil), the problem with this equation is that if the TEMP value doesn't equal to 25 then it says eval error, due to this when I enter a sepc for this, in the results tab although the spec is within rage but it still says Fail how can I fix this
    nil is not a valid value for an expression in ADE. The else part should return a number…
