  3. how to set xvalue for sawpsweep function as a variable
  • Subscribers 136
  • Views 3191
Purbayan
Purbayan over 1 year ago
i want to use a variable which has a predefined value of 20 that is Vicm=AVDD*0.5, where AVDD=40
but when i use VAR or ALIAS for the given function i always get an error that the xvalue is not a proper value.
swapSweep(waveform "TEMP" VAR("Vicm"))
swapSweep(waveform "TEMP" ALIAS("Vicm")) always give error
but if i use a number then it works for me
swapSweep(waveform "TEMP" 20)
How can i actually avoid this issue ?
