  3. Virtuoso Hierarchy Editor unable to find primitive resistor...
  • Subscribers 136
  • Views 2464
Virtuoso Hierarchy Editor unable to find primitive resistor/capacitor/inductor
Nett
Nett over 1 year ago
Hey everybody,
I'm having trouble getting Virtuoso Hierarchy Editor to remember what a primitive resistor/capacitor/inductor is.  These are vams cells that have previously compiled, but due to some unknown change in setup/software version are no longer accepted by the editor.
Any idea what might cause this/ what needs to be defined for the editor to understand the primitives?
Below is an image of the error.  When this same model was working correctly, none of these Capacitors/Resistors/Inductors were visible from the hierarchy editor as instances.
    Andrew Beckett over 1 year ago in reply to Nett +1
    I think it would need a definition of Resistor or Capacitor as these are not the built-in primitives (resistor and capacitor are). Anyway, I think these wouldn't cause a problem in practice since they…
    OK, these cells seem to be "Resistor", "Capacitor", "Inductor" (with an initial uppercase letter). Are there cells for these in a library? If so, try adding that library name to the library list in the config (top right of the hierarchy editor).
  • Nett
    Nett over 1 year ago in reply to Andrew Beckett
    Thanks Andrew,
    I tried re-compiling everything with lowercase names, and that didn't seem to restore the primitives.
    These aren't specific cells that I'm trying to call.  I was hoping to just use the "resistor" "inductor" and "capacitor" primitive definitions/ that are baked into the vams language.
    In previous projects, this code seems to have worked.  Is there some setting/definition that I have unintentionally set that would make the compiler start looking for cells instead of the primitives?
    I think it would need a definition of Resistor or Capacitor as these are not the built-in primitives (resistor and capacitor are). Anyway, I think these wouldn't cause a problem in practice since they will be bound inside the simulator. That said, to prevent netlisting failing, you might need to set:
    hnlInvalidBindingAction="ignore"
    in the .cdsinit/.simrc (or type in the CIW).
    Better might just be to add this to your cds.lib:
    DEFINE sample $(inst_root_with:tools/dfII/bin/virtuoso)/tools/dfII/samples/cdslib/sample
    and then open the verilogams view and hit the "build a database" icon (the "check and save"). The shadow database would then find these cells in the sample library, which would prevent the errors in HED (you might need to recompute the hierarchy in HED to clear the errors).
