  3. Issue Adding New Layers to Tech ASCII File in Virtuoso 6...
  • Subscribers 136
  • Views 4790
Issue Adding New Layers to Tech ASCII File in Virtuoso 6.1.7
JJ202502261359
JJ202502261359 over 1 year ago
I am a beginner and am trying to create a new tech ASCII file in Virtuoso 6.1.7.
I created a new "z15" library and ran "compile on ASCII technology file," and then I provided the following file:
~/tech/abcde.tf
layerDefinitions(
techLayerPurposePriorities(
;( LayerName Purpose )
( snap drawing )
( snap1 drawing )
) ;techLayerPurposePriorities
techDisplays(
;( LayerName Purpose Packet Vis Sel Con2ChgLy DrgEnbl Valid )
( snap drawing snap t t t t t )
( snap1 drawing snap t t t t t )
) ;techDisplays
) ;layerDefinitions
However, I receive the following errors:
Library Manager created library "z15"
INFO (TECH-180006): Compiling class 'layerDefinitions'....
*WARNING* (TECH-280074): Layer snap1 was not defined.
*WARNING* (TECH-280082): *ERROR* Failed to define layer-purpose priority for (snap1 drawing).
*WARNING* (TECH-280085): *ERROR* Failed to define layer display for (snap1 drawing snap t t t t t).
My goal is to add a new layer,
but it seems that any layer name not included in the "All LPPs" list in Tool -> Display Resource Manager -> Edit -> All LPPs causes the error above.
Can anyone provide guidance on how to add a layer, such as "snap1",
to the ASCII technology file even if it's not listed in the "All LPPs" section?
Thanks!
    You'd need to define the layer snap1 within techLayers before you can refer to it in a techLayerPurposePriorities or techDisplays section. snap is a system defined layer, but snap1 is not. techLayers is where you associate a layer name with a layer number (layers are stored on integer layer numbers).
  • JJ202502261359
    JJ202502261359 over 1 year ago in reply to Andrew Beckett
    Thank you.
    I wrote it as follows, and it worked!
    layerDefinitions(
    techLayers(
    ( snap1 100 snap1 )
    ( snap drawing )
    ( snap1 drawing )
    techDisplays(
