  3. Unbound Variable 'red' in ASCII Technology File
  • Subscribers 136
  • Views 1018
JJ202502261359
JJ202502261359 over 1 year ago
I created a layer for MTL1 and connected the packet to red as shown below.
Then, I executed the "Compile an ASCII technology file" and linked the *.tf file.
drDefineColor(
;( DisplayName ColorName Red Green Blue Blink )
( display red 255 0 0 )
drDefinePacket(
;(Display PacketName Stipple LineStyl Fill Outline fillSt)
(display red blank solid red red x )
layerDefinitions(
techLayers(
;( LayerName Layer# Abbreviation )
;User-Defined Layers:
( MTL1 100 MTL1 )
) ;techLayers
techLayerPurposePriorities(
;( LayerName Purpose )
( MTL1 drawing )
) ;techLayerPurposePriorities
techDisplays(
;( LayerName Purpose Packet Vis Sel Con2ChgLy DrgEnbl Valid )
( MTL1 drawing red t t t t t )
) ;techDisplays
) ;layerDefinitions
The library manager created the library "test000", but the following errors occurred:
INFO (TECH-180006): Compiling class 'drDefineColor'....
*WARNING* (TECH-280181): *Error* eval: unbound variable - red.
INFO (TECH-180006): Compiling class 'drDefinePacket'....
INFO (TECH-180006): Compiling class 'layerDefinitions'....
What is the cause of this error?
    JJ202502261359 said:
    drDefineColor(
    drDefinePacket(
    This part is not valid tech file syntax. This is from a display.drf file and would not be in the tech file itself. The parser uses the SKILL parser and hence sees the drDefineColor as a class, and is not expecting the word red - either way, it's not going to work.
