  3. How do I select data set for Explorer->Direct Plot ?
  • Subscribers 136
  • Views 1601
BillH314
BillH314 over 1 year ago
If I run a simulation in Explorer then want to plot results from clicking schematic nodes using Explorer -> Direct Plot it works great.   But I'm not sure how to load a specific data set.   There's a Results->Select option but it always only shows Explorer.0
1.   If I run a simulation in Assembler then try to descend into Explorer to use Results->Direct Plot to view the results of one of the Assembler Runs, e.g. Interactive.XX then I don't see how to do that.
2.   If I run a corner simulation and I only want to pick the results for one specific corner instead of plotting the entire family of curves when I use Results->Direct Plot I don't see how to do that either.
Using Virtuoso IC23.1-64b.ISR8.40
Thank you!
    You can only do Results->Select on results from Explorer that you've saved (e.g. using Results->Save in Explorer). You can't use it to retrieve Assembler histories.
    You can (however) use Right Mouse->View Results over a history in Assembler, then descend into Explorer, look at the Results tab and you'll see the results for that history. If you Direct Plot you will then get across all the corners. Or use Right Mouse->Direct Plot over an output and corner column cell and then you can Direct Plot for that corner (you can do this in Assembler too).
  • BillH314
    BillH314 over 1 year ago in reply to Andrew Beckett
    Thank you so much Andrew.   That works great.
