  3. HBSP simulation of Gilbert Cell Mixer
  • Subscribers 136
  • Views 3801
HuyDo
HuyDo over 1 year ago
I design a Gilbert Cell mixer with the following port detail:
LO: 4.9 GHz (from VCO)
Port1 (RF) : 2.5 GHz
Port2 (IF) : 2.4 GHz
and I'm running hb/hbsp analys
here I want to find out how many dB that signal at 2.5GHz leaking from RF port is attenuated at IF port - RF-to-IF isolation.
So I plotted S21 (dB)
I know that S-parameter does not capture the frequency change but here the isolation is measured at a specific frequency (2.5GHz)
To double check, I also plotted the hb spectral result to see the isolation and found that the 2 number were closed ( some dB different)
So I want to know if my S21 hbsp result is consider valid in this case
Thank you so much.
