  3. How to include variable in PSS command
  • Subscribers 136
  • Views 3941
sjwprcker
sjwprcker over 1 year ago
Hi, I am using command in .scs file to run pss simulation as
-> pss pss fund=10k harms=1200 errpreset=conservative tstab=100u annotate=status
this pss simulation is fine
if I change the fund value to a variable as
-> pss pss fund=VAR("freq_swp") harms=1200 errpreset=conservative tstab=100u annotate=status
the log reports that VAR is not known by spectreRF.
However, if I use VAR("freq_swp") in the GUI based PSS setting window, it passes.
Is there any solution to do so in command format?
BR
    VAR("freq_swp") is ADE syntax for passing variables. With Spectre, this just translates into a global (top-level in the netlist) parameter called "freq_swp" which would be defined at the top of the netlist typically (although the order doesn't matter):
    parameters freq_swp=10k
    and then in the analysis statement it would be:
    pss pss fund=freq_swp harms=1200 errpreset=conservative tstab=100u annotate=status
  • sjwprcker
    sjwprcker over 1 year ago in reply to Andrew Beckett
    Hi Andrew, that is cool, thanks a lot!
