  3. Virtuoso ADE dc analysis incorrectly turned to multiple...
  • Subscribers 136
  • Views 6507
Virtuoso ADE dc analysis incorrectly turned to multiple design point mode
SimbaG
SimbaG over 1 year ago
Key Issue:
My Virtuoso ADE environment consistently treats simulations as multiple design point simulations, even when there is only one "design point."
Observed Behavior:
  1. Even when performing a very simple DC analysis:
    • All sweep options are disabled.
    • No corner simulations or parameter variations are included.
    • A completely new ADE Maestro view is created.
  2. The environment still incorrectly identifies the simulation as having multiple design points; while actually there is only one design points.
  3. This behavior seems abnormal, given the minimal configuration for such a simulation.
Impact on Functionality:
This issue also affects the plotting capabilities in the Main Form. Upon attempting to plot, the following error occurs:
ERROR (WIA-1006): Unable to plot expression <v("/Iin" ?result nil)>
because it does not evaluate to an object that can be plotted, like a waveform or
parametric wave. See the Visualization & Analysis Tool documentation for information
about the types of objects that can be plotted in Visualization & Analysis Tool. Only
the expressions that evaluate to those objects can be plotted.
Additionally:
  • The expression v("/Iin" ?result nil) does not work for plotting.
  • The expression v("/Iin" ?result dc) also fails to produce a plot.
  • However, the expression VDC("/Iin") works correctly and yields the expected results.
Environment Versions:
Here are the relevant version details of the tools I am using:
virtuoso -W
sub-version IC23.1-64b.43
spectre -W
sub-version 23.1.0.442.isr7
Thank you in advance for your help!
    The Direct Plot form is designed to plot waveforms here, and it's getting confused by the lack of a sweep. The resulting expression is wrong - using ?result nil makes no sense. Similarly, since you only did a DC operating point, using ?result 'dc (it should have a single quote in front of the analysis name, or you could use "dc" too) won't work either because no DC sweep was performed. You can however use:
    v("/Iin" ?result 'dcOp)
    When VDC() is plotted or v("/Iin" ?result 'dcOp) as a graph, there has to be some x-axis - so in the absence of any variables, the design point is used. There is a design point - only a single design point though for a single simulation - I don't see anything in what you've said above that suggests there's multiple design points.
    So, other than the Direct Plot form not being better behaved with only a DC operating point, I don't see anything wrong here.
  • SimbaG
    SimbaG over 1 year ago in reply to Andrew Beckett
    In a previous version of Virtuoso (likely IC6.1.8, in ADE L), I remember the following behavior:
    1. When performing only a DC sweep, the "signal type output" would be displayed as a single number.
    2. Even when requesting to plot a number or a single design point waveform, the result would appear as a text box in the waveform window (unfortunately, I don't have a screenshot of this).
    However, in the current version, this behavior seems to have changed:
    • Now, the signal type always appears as a waveform, and I cannot directly get a numerical output.
    • To achieve a number, I must manually write expressions like VDC("/signal").
    • The Results -> Plot Outputs -> DC, is always grey, even if I save the DC operation point in DC analysis.
    Is this change due to the introduction of ADE Explorer? If this is the expected behavior, I suppose I just need to adapt to it.
    Andrew Beckett over 1 year ago in reply to SimbaG
    This has been an option for a long time - maybe you've turned it on for some point. Use Results→Plotting/Printing Options and check the Scalar Outputs for Single-Point Simulations checkbox in the Graph Annotations section (I can't upload a screenshot at the moment as the forum software is being difficult).
    For your points above:
    If it was a sweep, a single number wouldn't have been displayed (it wouldn't make sense). if it wasn't a sweep, a single value wasn't displayed as far as I know.
    This is the option I mentioned above.
    The Results->Plot Outputs->DC is for DC sweeps, not DC operating points. Results→Print→DC Node Voltages would give you the scalar outputs. Or you have to use VDC() or v(... ?result 'dcOp) to do this. This has always been the case.
  • SimbaG
    What I expected is when there is only one design point, Viva XL Waveform will plot it as "scalar outputs"
    As the following screenshots shows. Is it related tio EvalType in ADE?
