  3. can we use predefined techGetMPPTemplateNames without leHiCreateMPP...
  • Subscribers 136
  • Views 3693
can we use predefined techGetMPPTemplateNames without leHiCreateMPP directly unsing skill command like rodCreatePath
ebecheto
ebecheto over 1 year ago
Hi all,
I have a doubt. I like using gui tools when available and background skill tuning.
I have a predefined multipartpath (MPP) given by the fab or a colleague. I want to draw it automatically in that case using i suppose rodCreatePath.
Then, i will remove the unnecessary subpart with:
rod=rodGetObj(css());=> rodObj:0x5c8a19e0
m1=car(setof(part rod~>subParts part~>layer=="Metal1"));=> rodMPPSubpart:0x5c8a0340
rodDeleteSubPart(rod m1~>name)
I can find the MMP with :
tech=techGetTechFile(geGetEditCellView())
techGetMPPTemplateNames(tech);=> ("NRING" ...)
techGetMPPTemplateByName(tech "NRING") ;=> ((("ACTIVE" "drawing") 0.42 nil truncate 0.0 0.0 center 0.0) ((("Metal1" "drawing") 0.34 t 0.0 center 0.0 0.0)) ((("Nstuff" "drawing") -0.18 nil 0.0 0.0) (("NWell" "drawing") -0.44 nil 0.0 0.0)) ((("CONTACT" "drawing") 0.22 0.22 t 0.0 center 0.25 -0.13 -0.13 distribute nil 0.0 0.0)))
But i could not find so far a function that grab directly the output of techGetMPPTemplateByName to feed to rodCreatePath.
Should i 'foreach' it myself ?layer ?width  ?justification ... ?
i was expecting to use a rodCreateMPP("NRING" pts); with my list of points.
Anyone knows that type of function ?
Thanks for any tips.
    Andrew Beckett over 1 year ago +1
    See my article which provides a function to do this: Can I create a Multi Part Path in SKILL based on a technology file template? Andrew
  • ebecheto
    ebecheto over 1 year ago in reply to Andrew Beckett
    work like a charm!
    Thank you for my lack of searching properly.
    Although, search in community.cadence works better than in support.cadence, or i do know howto.
