  3. How to change text alignment in "Description" column of...
  • Subscribers 136
  • Views 1112
How to change text alignment in "Description" column of ADE Explorer
Volker T
Volker T over 1 year ago
Dear all,
I would like to change the alignment of text displayed in the "Description" column of ADE Explorer's "Output Setup" tab (IC23.1) of a maetro view.
There are environment variables like
envSetVal("adexl.gui" "headerAlignmentSide" 'string "Center")
(obviosly for ADEXL / ADE Assembler) or
envSetVal("maestro.gui" "nameDisplayWidthInDataView" 'cyclic "Interactive").
So, for a few things, one can set the behaviour / display style by envrionment variable.
Looking up the documentation for this, I did not manage to find any such environment variable defining text alignment in a specific column.
Is there any? Or, can I modify this at least somewhere in the GUI by some command / setting accessible by menu?
Thank you.
Volker
    Volker,
    I'm not aware of any mechanism to be able to change this - either interactively or via a cdsenv var.
  • Volker T
    Volker T over 1 year ago in reply to Andrew Beckett
    Thank you very much. Your answer is in line with my further investigations using Cdsenv Editor.
    After searching Cdsenv Editor for keywords "Center", "align" or "alignment", I guess the answer to my question indeed simply is: "You can't."
