  3. How to disable modelFiles display in the viva plot?
  • Subscribers 136
  • Views 3393
sjwprcker
sjwprcker over 1 year ago
In the viva plot, the annotation of the curve is always display some infos, such as
-Name
-Vis
-modelFiles
There are other options as
-Region
-History
-etc
I would like to config those options by environment variable and change them in default case. Are there any environment variables avalable for that?
Thanks!
    What do you mean by "annotation of the curve"? Regardless of what you mean, I'm not sure there's a way to control this (for example, there's CCR 3030728 to control the legends - difficult when the columns depend on the variables being swept - so would be a similar problem for tooltips or the waveform names if that's what you mean).
