  3. evaluation of "all" possible outputs
  • Subscribers 136
  • Views 1523
leok
leok over 1 year ago
I'm building a report generator. Users should be able to enter expressions as in the calculator and it should plot/evaluate them.
But I cannot find a skill expression to evaluate "all" possible results.
  • There is the "normal" expression evaluation from the psf file (working fine after openResults())
  • But for assembler outputs (the other database) my best choice is calcVal which is not always giving the same results as hitting plot in the calculator (e.g. for a sweep it returns only a scalar instead of a waveform).
So my high-level questions is: Is there any function that returns a waveform/scalar exactly as the calculator? That would be great as my users would check the expression there before they enter it in the report.
After fiddling for <waytoolong>, this is my best try:
        unless( s = catch(t evalstring(expr)) ; "normal" psf expression
          s = catch(t calcVal(expr selectedtest ?run historyprefix))) ; assembler database with runplan?
        unless( s
          s = catch(t calcVal(expr selectedtest ?historyName selectedhistory ?lib axlGetSessionLibName(mses) ?cell axlGetSessionCellName(mses)
                              ?view axlGetSessionViewName(mses)))) ; assembler 1.
        unless( s
                              ?view axlGetSessionViewName(mses) ?getFirstSweepPoint t))) ; assembler 2.
That does not look like it should be possible
Best Regards,
leo
  • leok
    Small addendum: A cadence restart helped this time.. But as you can see in the "grown" evaluation I faced these problems many times - so the calculator-equivalent would be helpful (and face the same bugs, so my users won't be confused and point to me ;) )
    Andrew Beckett over 1 year ago in reply to leok
    The closest is using calcVal to get a result output, but there isn't really a clean way to do this.
  • leok
    leok over 1 year ago in reply to Andrew Beckett
    thank you! Not really great, but at least I wasn't too far away ;)
    leo
