  3. Problem with a waveform
  • Views 4055
tomgerga
tomgerga over 1 year ago
I'd like to ask you if anyone would help me with this problem:
I am trying to make transient analysis where my parameter is "Rsens" variable. When the simulation is done, I have multiple values across parameter sweep shown below:
When I right-click the value and select "Plot All", I can see the points connected by lines. The problem is that I cannot use any calculator functions (such as deriv) because (I think) the plot is not considered as waveform and it says evaluation error.
Here are the functions.
Tosc1 ---- average((1 / freq(VT("/OSC_SENS_OUT") "rising" ?xName "cycle" ?mode "auto" ?threshold 0.0))) --- this gives me the values for each parameter.
when I try to use deriv, it does not work, saying evaluation error
or
when I try to make a slope from two points using this:
((ymax((1 / value(freq(VT("/OSC_SENS_OUT") "rising" ?xName "time" ?mode "user" ?threshold 0.0) VAR("StopTime"))) ?overall t) - ymin((1 / value(freq(VT("/OSC_SENS_OUT") "rising" ?xName "time" ?mode "user" ?threshold 0.0) VAR("StopTime"))) ?overall t)) / (xmax((1 / value(freq(VT("/OSC_SENS_OUT") "rising" ?xName "time" ?mode "user" ?threshold 0.0) VAR("StopTime")))) - xmin((1 / value(freq(VT("/OSC_SENS_OUT") "rising" ?xName "time" ?mode "user" ?threshold 0.0) VAR("StopTime"))))))
it still does not work.
NOTE: These functions work only in calculator. When I pass it to the maestro, it does not work.
Any help?
    You would need to change the EvalType column to sweep, corners, or all. In essence, the default EvalType is "point" which means that the expression only sees a single simulation result. With EvalType set to sweep, corners, all (or now "any") you can have a function that operates across a set of data.
    Some info here: Measuring Across Corners, Sweeps and All (Video) and Performing Measurements Across Sweeps and Measurements Across All in the ADE Assembler (Video)
