  3. ?suffixNotation input in noiseSummary
  • Subscribers 136
  • Views 3462
leok
leok over 1 year ago
It's not a big deal, but I would like to have the suffixNotation enabled when I use the noiseSummary function in a script. But I cannot find out what the value should be for turning it "on".
And this is a rare case where even Google has exactly 0 hits Disappointed
The help only tells me to use "nil" which is default and the opposite behavior.
Best Regards,
leo
  • leok
    UPDATE:
    It's just a bug. Everything besides nil will set it to print with suffix. But for some reasons it's not working in one assembler testbench, but in the other(s) it does. Maybe it is connected to noise analysis during tran, but I have no time to further dig into it...
    Failing expression (selects noise from corner, two sweeps and time (10u):
    noiseSummary('integrated ?result 'noise ?from 20k ?to 100M ?noiseUnit "V" ?suffixNotation t ?truncateData 10 ?truncateType 'top ?output p_out ?paramValues list("nom" "nom" 4u 60 10u))
    Example for good one (selects noise from one sweep:
    noiseSummary('integrated ?result 'noise ?from 20k ?to 100M ?noiseUnit "V" ?suffixNotation t ?truncateData 10 ?truncateType 'top ?output nil ?paramValues list(5u))
    Andrew Beckett over 1 year ago in reply to leok
    That's not a bug. That's how boolean values work in SKILL. nil is false, anything else is true (so t, 1, "hello" are all true). The documentation is misleading because of the t_suffixNotation (which suggests it's text/string) - I've given feedback on the docs to fix that.
    I can't really help with what's wrong in your Assembler setup - I suggest you contact support via http://support.cadence.com (use the case menu to submit a case) so we can investigate and help.
