  3. How to get the valid instance db_Id "d_instId" of a instance...
  • Subscribers 136
  • Views 1475
YC202502167727
YC202502167727 over 1 year ago
I am trying using "dbFlattenInst2" skill to smash a instance.
skill:  dbFlattenInst2(  d_instId    x_levels   [ g_options ] )  => t / nil
and the Arguments says the definition of "d_instId"  is "Specifies the database ID of the instance to flatten.
Then I tryed to find out this d_insld by using (geGetEditCellView)->instances~>? ?
I have put the content that produced by (geGetEditCellView)->instances~>? ?  one by one into the d_instId position and all failed.
For  xample:     dbFlattenInst2( 0x7b6555a0  2 )      → from  ((db:0x7b6555a0 cellView db:0x7b65519a objType...
                or       dbFlattenInst2( 0x6d422e1a  2 )     →from      ... master db:0x6d422e1a ...
I really have no clue about the exact location and appearance of the "d_instId"
Any advise would be helpful and thankful.
Best Regards.
    Andrew Beckett over 1 year ago +1
    When Virtuoso prints out a database id, it shows it with the print representation as you've seen - for example db: 0x7b6555a0 . You cannot just type this in as a literal value to be passed to another function…
    When Virtuoso prints out a database id, it shows it with the print representation as you've seen - for example db:0x7b6555a0 . You cannot just type this in as a literal value to be passed to another function - it's merely there to print something that gives an indication that it's a database id, and that two database id's with the same address mean the same object.
    Instead you need to process this list so that the database ids are directly referenced or stored in a variable. For example:
    instances=geGetEditCellView()~>instances
    ; flatten just the first
    ;dbFlattenInst2(car(instances) 2)
    ; or flatten them all one by one
    foreach(inst instances
      dbFlattenInst2(inst 2)
  • YC202502167727
    YC202502167727 over 1 year ago in reply to Andrew Beckett
    Hi Andrew
    Thank you four your detailed reply.
    The code is running smoothly and I finally understand how to use the database ids.
    Thanks again!
    Best Regards.
