  3. Enclosure of well layer in fluid guard ring on chamfers
  • Subscribers 136
  • Views 2984
JC202503222156
JC202503222156 over 1 year ago
hi all,
I'm using IC6.1.8.500.15.I‘ve installed some fluid guard rings and created them.And they work perfectly on rectilinear edges.
One thing I found odd is that in some cases while on a chamfer,the well layer's enclosure is a little less than the number I was set in techfile,which causes DRC violation.
I never saw this in MPPs.
Am I missing something during the FGR installation or creation?
Other than add another well shape manually,is there a more elegant solution?
Also,after I install FGRs by the Install Guard Ring Form,there are a lot more parameters in techfile than I was filled in the form.
I can understand yDiffEncCont and xDiffEnclCont ,these are minimum Diff enclosure W&L  I set in the form.
But where are parameters like diffEncCont1 diffEncCont2  metalEncCont1 metalEncCont2 come from , what the meaning of them?
Thank you.
Joshua
