  3. Using Existing Calculator Functions in Custom SKILL Functions...
  • Subscribers 137
  • Views 4671
Using Existing Calculator Functions in Custom SKILL Functions for ADE Assembler
baltaci
baltaci over 1 year ago
I am currently developing custom calculator functions using SKILL for use within ADE Assembler, and I would like to confirm whether it is possible to reuse existing built-in calculator functions (such as lshif, clip, deriv, etc.) directly within my SKILL code.
For example, if I want to define a custom waveform function that internally uses a left shift or applies a clipping operation, can I call these built-in functions from my SKILL implementation — or are they only available through the ADE calculator GUI?
If this is supported, could you kindly provide a very simple working example of a custom SKILL function that internally uses one of these existing calculator functions (e.g., lshif or clip)?
I would greatly appreciate your help or any official documentation that explains this behavior.
Best regards,
Can
  • Volker T
    Volker T over 1 year ago
    Sure you can. Simple example using clip function to clip from first waveform value to specified end of waveform values:
    procedure( clipTo( signal to )
        (cond
            ((drIsWaveform signal)
                clip(signal firstVal(signal) to)
            ((famIsFamily signal)
                (famMap 'clipTo signal to)
            (numberp(signal)
                signal
            (t
                (error "clipTo: Signal %L is neither a waveform, nor a waveform family.\n" signal)
    You see, the function uses the standard "clip" function, but inserts firstVal(signal) as start of clipping, again "firstVal" being a calculator function.
    Andrew Beckett over 1 year ago in reply to Volker T
    Thanks for this - you beat me to it!  Joy
    A small (rather pedantic) point - you could just use clip(signal nil to) - if nil is specified as one of the clip limits, it defaults to the first (or last if it's the third argument) point.
    However, the key point here was to show a simple example, and you did that beautifully - thanks very much!
  • Volker T
    Volker T over 1 year ago in reply to Andrew Beckett
    Andrew, any "pedantic" points that make the code more efficient are very welcome on my side...Thumbsup
