  3. Facing "Segmentation Fault" error while trying to run Assura...
  • Subscribers 136
  • Views 2225
Facing "Segmentation Fault" error while trying to run Assura DRC for layout analysis.
AP202504073541
AP202504073541 over 1 year ago
I am facing "Segmentation Fault" error. I am trying to run DRC using Assura for layout analysis in Cadence Virtuoso.
Though I have attached the appropriate technology file and completed other steps correctly, I am still facing this error in DRC as well as LVS analysis.
I am Screenshot of this error is attached.
    Not enough information to go on (no info on versions used; I'd expect there to be some detailed log with more information). Please contact customer support.
  • RobMan
    RobMan over 1 year ago
    What version of Assura?
    What version of Virtuoso?
    Submitted from the gui?
    OA db or gds for the  layout?
    N.B. The question clearly does not contain enough information to get close to the cause of the issue.
  • AP202504073541
    AP202504073541 over 1 year ago in reply to Andrew Beckett
    The versions are :
    IC 6.1.8
    Assura 4.1 USR6 HF13
  • RobMan
    RobMan over 1 year ago in reply to AP202504073541
    IC618 was release in 2018 so this gives me no idea whether you are using a recent release or not.
    The Assura release is from 2022... So quite old.
    I suggest you try...
      Recent (latest if possible) release.
      Run with gds (if you are not doing this). This would help identify OA db issue.
    As Andrew suggests; contacting customer support might be the best approach.
    If you are looking for help on the forum please consider the detailed level of information that might be required to identify any issues.
  • AP202504073541
    AP202504073541 over 1 year ago in reply to RobMan
    Ok. Thank you for your response.
