  3. How to implement the SimVision Expression Calculator with...
  • Subscribers 136
  • Views 5957
How to implement the SimVision Expression Calculator with tcl
Chandru Dhandapani
Chandru Dhandapani over 1 year ago
Hi.
I am using SimVision for Analog-Mixed Signal (AMS) simulations. Within SimVision, I have probed certain signals, such as currents, for analysis.
To calculate the range average of these signals after my simulation, I am using the Expression Calculator in SimVision. This approach is dynamic.
The expression I am using is as follows:
range_average((waves::signal1_$flow + waves::signal2_$flow), 10us, 50us)
However, I need to automate this operation for post-processing purposes.
To achieve this, I have developed a TCL script. Unfortunately, the script only works partially and does not fully meet the required functionality.
Could anyone provide guidance on how to implement this requirement effectively? Are there any alternative methods or improvements I can make to my approach?
script:
# Step 1: Open the waveform database
if {[catch {database open waves.shm} errorMessage]} {
puts "Error: Failed to open waveform database. Details: $errorMessage"
return
# Step 2: Define signals and the combined signal
set signal1 "signal1_$flow"
set signal2 "signal2_$flow"
set combined_signal "$signal1 + $signal2"
# Step 3: Create the average calculation expression
set expression "range_average(($combined_signal), 1 us, 70 us)"
set avg_value ""
# Step 4: Create the condition and check for errors
if {[catch {condition new -name range_avg_cond -expr $expression} errorMessage]} {
puts "Error: Failed to create condition. Details: $errorMessage"
database close
return
} else {
puts "Debug: Condition 'range_avg_cond' created successfully."
# Step 5: Allow processing (optional delay based on waveform size)
after 1000
# Step 6: Retrieve the calculated result
if {[catch {set avg_value [condition get -name range_avg_cond]} errorMessage]} {
puts "Error: Failed to retrieve condition value. Details: $errorMessage"
database close
return
# Ensure the average value is valid
if {[string length $avg_value] == 0} {
puts "Error: Unable to calculate the average. Check the expression or signals."
database close
return
# Step 7: Print the result to the console
puts "The average value is: $avg_value A"
# Step 8: Generate the report file
set report_file [open "report.txt" w]
puts $report_file "SimVision Analysis Report"
puts $report_file "------------------------"
puts $report_file "Signal 1: $signal1"
puts $report_file "Signal 2: $signal2"
puts $report_file "Time Window: 1 us to 70 us\n"
puts $report_file "Sum Expression: $combined_signal"
puts $report_file "Average Expression: $expression"
puts $report_file "Average Value: $avg_value A\n"
close $report_file
puts "Report generated: report.txt"
# Step 9: Optionally create a waveform window and display the condition
window new WaveWindow
waveform add -signals {range_avg_cond}
update
# Step 10: Close the waveform database
database close
##run command. simvision -input <tcl_file>
Note: I can able to see expression function results in new waveform window. But, not in report file or console window. I want to see in report file/ console.
